Ansys Learning Forum Forums Discuss Simulation Fluids Patch Initialization in TUI 2019R2 Reply To: Patch Initialization in TUI 2019R2
No, Field Functions would give you (for example) a way to set another value as a function of position. So Temperature = f(x-coordinate) as an idea. I think for 2019 you'd need to use an adaption register to split off some cells. It's a good reason to update to the new release! I can't check 2019 as I don't have it installed.
You may need to check Fluent saved a local path for the mechanism (ie ./my_stuff as opposed to c:/stuff/random/more_stuff ) but otherwise, yes it should be OK. A colleague covers Chemkin and the other combustion tools and I've not heard of any issues moving to our cluster from a desktop.
