Ansys Learning Forum Forums Discuss Simulation Fluids Conditional solution Reply To: Conditional solution
SRP
Yes, you can set up a two-phase cooling simulation. You can achieve this by writing a UDF that updates the HTC based on the flow conditions at each time step or iteration. Use a UDF to calculate the HTC based on the local flow conditions, such as Reynolds number, Nusselt number, or any other relevant parameters
