Ansys Learning Forum Forums Discuss Simulation Fluids Ansys Fluent UDF: DEFINE_DPM_BC Reply To: Ansys Fluent UDF: DEFINE_DPM_BC
kiran.purushothamakeshavan
I think the issue was with the order of each force quantities, it was in the scale if E-09 or E-11 so I used a factor which multiplied these insignificant quantities to compare with the others.
anyway, now my question is simple, I get to see how many particles stick and how many bounce from the object. How do I visualise the contours for the same? I would want to display the particle adhesion on a surface as a heatmap.
here is my code:
#include “udf.h”
#include “dpm.h”
#define mu 0.5
#define PI 3.14
real FD(real diam, real velocidad)
    return ((1/2) * 1.225 * 0.44 * M_PI*(((diam)*(diam))/4) * (velocidad*velocidad));
FILE *fp1;
FILE *fp2;
FILE *fp3;
//real x[3];
//x[0] = 0.0;   // Assign value to the x component
//x[1] = 0.0;   // Assign value to the y component
//x[2] = 0.0;   // Assign value to the z component
DEFINE_DPM_DRAG(particle_drag_force, Re, p)
    FILE *fp1;
    real w, drag_force, F, nf, ff, ff123;
    Thread* tcell = P_CELL_THREAD(p);
    cell_t c = P_CELL(p);
    real relVel[ND_3], dvtdn, fluidVel[ND_3];
    if (Re < 1)
        drag_force = 18;
    else if (Re < 20.0)
        w = log10(Re);
        drag_force = 18.0 + 2.367 * pow(Re, 0.82 – 0.05 * w);
    else
        drag_force = 18.0 + 3.483 * pow(Re, 0.6305);
    NV_D(fluidVel, =, C_U(c, tcell), C_V(c, tcell), C_W(c, tcell));         //assigning fluid velocity components to vector
    NV_VV(relVel, =, fluidVel, -, P_VEL(p));                        //calculating relative velocity of flow on particle by subtracting absolute particle velocity from fluid velocity
    dvtdn = NV_MAG(relVel);                                 //calculation of relative velocity magnitude
    // P_USER_REAL(p, 0) = FD(drag_force, C_MU_L(c, tcell), P_RHO(p), P_DIAM(p), P_MASS(p), dvtdn); /*Drag force*/
    P_USER_REAL(p, 0) = FD(P_DIAM(p), dvtdn); /*Drag force*/
    P_USER_REAL(p, 1) = dvtdn;
    // F = (1/2)*1.225*0.3*M_PI*(((P_DIAM(p))*(P_DIAM(p)))/4)*(dvtdn*dvtdn);
    // F = (1/2)*1.225*0.3*10000000*M_PI*(((P_DIAM(p))*(P_DIAM(p)))/4)*(dvtdn*dvtdn)*(10000000000);
    // P_USER_REAL(p, 2) = F;
    // nf = C_P(c, tcell) * M_PI (((P_DIAM(p))*(P_DIAM(p)))/4) *10000000000;
    fp1=fopen (“Impact-2-drag-data.txt” , “a”);
    // fprintf( fp1 , “%e %f %e %f %f %e %e\n”, P_USER_REAL(p, 0), P_USER_REAL(p, 1), P_USER_REAL(p, 2), drag_force, P_DIAM(p), F, P_USER_REAL(p, 3));
    real diameter_squared = P_DIAM(p) * P_DIAM(p);
    real area_term = (diameter_squared) / 4;
    real velocity_term = dvtdn * dvtdn;
    real constant_factor = (1.0 / 2.0) * 1.225 * 0.3 * PI;
    F = constant_factor * area_term * velocity_term * (10000000);
    nf = C_P(c, tcell) * (PI/4.0) * diameter_squared *10000000;
    ff = mu * nf;
    ff123 = ff;
    P_USER_REAL(p, 3) = ff123;
    fprintf(fp1, “Area Term: %e, Velocity Term: %e, F (final): %e, Constant factor: %e, friction force: %e, Normal force: %e\n”, area_term, velocity_term, P_USER_REAL(p, 2), constant_factor, P_USER_REAL(p, 3), nf);
    fprintf(fp1, “Pressure: %e,  ff123: %e\n”, C_P(c, tcell), ff123);
    fclose(fp1);
    return (drag_force);
DEFINE_DPM_BC(wall_model, p, t, f, f_normal, dim)
    real alpha;  /* angle of particle path with face normal */
    real vn=0.;
    real nor_coeff = 0.3;
    real tan_coeff = 0.3;
    real normal[3];
    int i;
    real posx, posy, posz;
    // real NV_VEC(x);
    real x[ND_ND];
 //#if !RP_HOST
    #if RP_2D
  //dim is always 2 in 2D compilation. Need special treatment for 2d axisymmetric and swirl flows
  if (rp_axi_swirl)
      real R = sqrt(P_POS(p)[1]*P_POS(p)[1] +
                    P_POS(p)[2]*P_POS(p)[2]);
      if (R > 1.e-20)
          idim = 3;
          normal[0] = f_normal[0];
          normal[1] = (f_normal[1]*P_POS(p)[1])/R;
          normal[2] = (f_normal[1]*P_POS(p)[2])/R;
      else
          for (i=0; i
            normal[i] = f_normal[i];
  else
    #endif
    for (i=0; i
        //Message (“Text \n”);
    if (p->type == DPM_TYPE_INERT)
        if (fabs(P_USER_REAL(p, 2)) < fabs(P_USER_REAL(p, 3)))
        // Particle bounce: Aerodynamic force > Pressure force on particle. So particle must be resuspended to the flow.
            posx = P_POS(p)[0];
            posy = P_POS(p)[1];
            posz = P_POS(p)[2];
            P_USER_REAL(p, 4) = posx;
            P_USER_REAL(p, 5) = posy;
            P_USER_REAL(p, 6) = posz;
            for(i=0; i
                P_VEL(p)[i] = 0;
            P_USER_REAL(p, 7) += 1.;
            fp2=fopen (“Impact-Stick.txt” , “a”);
            fprintf( fp2 , “Force due to aero (Fa): %f, Friction force (ff): %f, How many stick? = %f, x coordinate: %f, y coorfdinate: %f, z coordinate: %f\n”, P_USER_REAL(p, 2), P_USER_REAL(p, 3), P_USER_REAL(p, 7), P_USER_REAL(p, 4), P_USER_REAL(p, 5), P_USER_REAL(p, 6));
            fflush(fp2);
            fclose(fp2);
            return PATH_ACTIVE;
        else
            alpha = (PI/2.0) – acos(MAX(-1.,MIN(1.,NV_DOT(normal,P_VEL(p))/ MAX(NV_MAG(P_VEL(p)),DPM_SMALL))));
            if ((NNULLP(t)) && (THREAD_TYPE(t) == THREAD_F_WALL))
            F_CENTROID(x, f, t);
            /* Compute normal velocity. */
            for(i=0; i
            vn += P_VEL(p)[i]*normal[i];
            /* Subtract off normal velocity. */
            for(i=0; i
            P_VEL(p)[i] -= vn*normal[i];
            /* Apply tangential coefficient of restitution. */
            for(i=0; i
            P_VEL(p)[i] *= tan_coeff;
            /* Add reflected normal velocity. */
            for(i=0; i
            P_VEL(p)[i] -= nor_coeff*vn*normal[i];
            /* Store new velocity in P_VEL0 of particle */
            for(i=0; i
            P_VEL0(p)[i] = P_VEL(p)[i];
            P_USER_REAL(p, 8) += 1.;
            fp3=fopen (“Impact-Bounce.txt” , “a”) ;
            fprintf(fp3 , “Force due to aero (Fa): %f, Friction force (ff): %f, Number of particles bounced: %f\n”, P_USER_REAL(p, 2), P_USER_REAL(p, 3), P_USER_REAL(p, 8));
            fflush(fp3);
            fclose(fp3);
            return PATH_ACTIVE;
    else
        return PATH_END;
 //#endif
