Ansys Learning Forum Forums Discuss Simulation General Mechanical SMART crack error problem Reply To: SMART crack error problem
David Weed
You may want to try refining the base mesh around the location of the crack mesh so that the transition from the crack mesh to base mesh is a bit better; the base mesh looks somewhat coarse from the picture shown. You can use a local sizing option such as sphere of influence using the crack coordinate system as a point of reference.
