Ansys Learning Forum Forums Discuss Simulation Electronics Changing Polarity Type for Coil Reply To: Changing Polarity Type for Coil
Timos
Hello, to alternate polarity between Positive and Negative during a simulation in Ansys Maxwell, you can use the 'Function' polarity type to define a mathematical expression or a predefined function that dictates the polarity change. This function can be a sinusoidal function which would allow the polarity to change in a sinusoidal manner without manually changing the coil settings each time. Moreover, you can simply select possitive or negative polarity and then by using an appropriate function directly in the winding setup you can alternate the polarity of the current.
