Ansys Learning Forum Forums Installation and Licensing Ansys Products How to select special areas in APDL? Reply To: How to select special areas in APDL?
deepak.deepak
ASEL: Selects a subset of areas. Using this u can select the area by their numbers.
ASEL,S,AREA,,2,          #Select a new set with area no. 2
ASEL,A,AREA,,4,9,5     #Additionally select a set, with areas for 4 to 9 at an increment of 5 (i.e., area no. 4 and 9) to the current set
ASEL,A,AREA,11,13,    #Additionally select a set, with areas for 11 to 12 at an increment of 1 (i.e., area no.11,12,13) to the current set
..................................    # You can select the remaining areas.
APLOT,                          # Plots the current area selection set in the graphic window.
Using the CM command you can give a component name (named selection) to the current selection.
Refer: ASEL (ansys.com) | CM (ansys.com)
Thanks
Deepak
