Ansys Learning Forum Forums Discuss Simulation Preprocessing Working with a model after using MODMSH,DETACH on APDL Reply To: Working with a model after using MODMSH,DETACH on APDL
dlooman
If you assign the elements of each volume a different attribute number such as material set number you can select by that.  That's all you are giving up with modmsh,detach.  The ability to select by solid model entities.
