Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Mesh size restrictions Ansys Electronics Student version › Reply To: Mesh size restrictions Ansys Electronics Student version
August 16, 2024 at 12:20 pm
Hi Mitchell,
The error you are getting is not dependent on the number of passes given in the solution setup. Ansys HFSS software does estimate the mesh elements required for analysis based on the initial mesh settings. While doing so it found that this estimate is beyond the student version limitation.
You can simplify the model so that mesh elements count falls below the student version limitation or use commercial if the model cannot be simplified.
Hope this helps.
Best regards,
Praneeth.
