Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent expression syntax error › Reply To: Fluent expression syntax error
August 16, 2024 at 12:07 pm
The expression does not evaluate to a single value because of StrainRate, which is a tensor field. Your expression will depend on the value of StrainRate at a given location.
The message you are seeing is not an error, you should still be able to create this expression and visualize it in contour plots for example.
