Ansys Learning Forum Forums Discuss Simulation LS Dyna ICFD Mesh error: Surface Collapse not possible to locate Reply To: ICFD Mesh error: Surface Collapse not possible to locate
Reno Genest
Hello Arnaud,
If DT=0 on *ICFD_CONTROL_TIME, then the CFL timestep calculated by the ICFD solver is used:
You could try to use a larger DT by specifying the timestep you want to use (DT=5e-6 for example) and see if the results are still good.
Also, you could try to increase your mesh size a little bit.
Finally, it is recommended to use MPP LS-DYNA to run in parallel on many cores.
Reno.
