Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Setting Up MRF Case › Reply To: Setting Up MRF Case
August 15, 2024 at 10:14 am
I didn’t update the name, it’s meant to be side-wall.Â
The reason why I want to use MRF over SRF is because whilst the current unbaffled mixer is operating in batch, I intend to model precipitation reactions in the mixer which are operated continuously (so inlets and outlets will be added to the model). Due to the addition of these stationary components, MRF would be better than SRF in transitioning from batch mixer to semi-batch/continuous mixer.
