Ansys Learning Forum Forums Discuss Simulation Fluids Setting Up MRF Case Reply To: Setting Up MRF Case
ll17s5r
Apologies the images didn't render properly. So the stirrer (inside the MRF) is defined as moving wall with 0 RPM relative to the cell zone. Whereas the side wall and bottom (outside the MRF) can be left as stationary walls.
