Ansys Learning Forum Forums Discuss Simulation Fluids Ansys stopped simulation due to PC restart Reply To: Ansys stopped simulation due to PC restart
Every 0 means it's off.  Unless you're using geometry parameters export the initial case & data (ie once Fluent is set up) and run Fluent from the Start menu. Set autosave to a sensible name and directory & run. If/when the PC or solver fails restart, read in case & data and continue.Â
