Ansys Learning Forum Forums Discuss Simulation Fluids Meshing heat exchanger initial simulation no baffles Reply To: Meshing heat exchanger initial simulation no baffles
joel.sayers
When upping the divisions majorly it slowly is climbing the mesh quality up, this is a nearly 4 metre part as the hot fluid, what do you think is a realistic ball park cell count for this sort of thing as it is now up to nearly 4mil which seems a bit excessive.
