Ansys Learning Forum Forums Discuss Simulation LS Dyna Opening LSDA format file cbisfor Reply To: Opening LSDA format file cbisfor
gcongdon
Thank you! Apparently, in the latest version of the downloadable, there is a Python version as well as a C version of the program. The docs on how to use either are really sparse, but this should be all I need to get at the contents in the file hopefully. Otherwise I'll install the latest dev version of ls pre/post to see if they have added the functionality to open the filetype.
