Ansys Learning Forum Forums Discuss Simulation Fluids Setting Up MRF Case Reply To: Setting Up MRF Case
I can't see images in the second post.
The stirrer walls should move at zero rpm relative to the cell zone, which should be rotating at whatever speed you want. Side & bottom can be stationary as their fluid region won't be moving.
