Ansys Learning Forum Forums Discuss Simulation Fluids Double Pipe Heat Exchanger Reply To: Double Pipe Heat Exchanger
You may want to initialise from hot (or cold) inlet and then use Patch for the other channel. If you're wanting to plot contours etc look at isosurface & planes: they're widely used in the tutorials that are in Fluent's Help system.
