Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Deleting/Adding mid nodes using EMOD on APDL › Reply To: Deleting/Adding mid nodes using EMOD on APDL
August 14, 2024 at 3:04 pm
Leon15
Hello,Â
Thank you for the quick reply. I was using the graphical interface (Plot, Nodes) to verify the effetiveness of the command, but in the GUI the mid nodes still appear even though they have been deleted (I assume it is because the elements are still labeled as solid 279). However, using the command ELIST did show that indeed the mid nodes had been deleted. Â
Cheers,
Leon
