Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Regarding Litz wire in Eddy current type › Reply To: Regarding Litz wire in Eddy current type
August 14, 2024 at 12:42 pm
Hello Poonam,Â
Please follow below steps:
- Create a circle in 2d Maxwell Eddy current solver.
- Assign Copper on that circle, while assigning clone the copper and select the composion as litz and enter the values as given belowÂ
3. Assign coil terminal on that circle and enter the no. of conductors as 1.
4. Add that coil terminal to winding as given belowÂ
5. Add the parameters for parametric analysis as belowÂ
6. set the operating frequency and enable the matrix on the winding and run the model.
7. We can define the Rac and Rdc as given below
8. We will get below results for 1 meter length conductorÂ
9. We can check Rac in the solution matrix tab alsoÂ
Hope this will help you.
Thank you,
Harinath Vudumula.
