Ansys Learning Forum Forums Discuss Simulation Fluids Meshing heat exchanger initial simulation no baffles Reply To: Meshing heat exchanger initial simulation no baffles
OK, that'll be because of the number of tubes. If you try with the tube sizing and don't set anything for the end face what happens? You may need to alter the cell growth rate.Â
