Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › compression limit to a spring element › Reply To: compression limit to a spring element
August 14, 2024 at 10:03 am
Hi Bushetty,
There is no direct way to control the compression of the spring at a certain position, but you can control the compression position by controlling the stiffness of the spring. By defining the actual stiffness up to the desired compression length, and defining the very large stiffness value beyond that length.
Refer: 9.8. Springs (ansys.com), Part 4 :- Different type of spring modelling in ANSYS Mechanical (youtube.com)
Thanks
Deepak
