Ansys Learning Forum Forums Discuss Simulation Photonics CHARGE simulation: dark current vs. Surface recombination velocity Reply To: CHARGE simulation: dark current vs. Surface recombination velocity
handon
Yes, I set the hole and electron sat velocities at the same values in each simulation.
And you could see an increase in the current with increase in surface recombination.
I wonder what's the difference with my simulation and yours.
Can you share your pn junction test files?
