Ansys Learning Forum Forums Discuss Simulation General Mechanical Set up time steps more efficiently Reply To: Set up time steps more efficiently
mjmiddle
In most cases, probably not unless you were careful to use the same IDs written by Mechanical, such as real constants, element type IDs, etc...
The loads you define by APDL will usually be separate and additional from what Mechanical writes.
But there could be some conflict applying the same type of load on the same nodes or elements.
