Ansys Learning Forum › Forums › Discuss Simulation › Optics › Mix color with Integrating sphere or sensor in LED RGB sourse › Reply To: Mix color with Integrating sphere or sensor in LED RGB sourse
August 13, 2024 at 8:55 pm
It depends on the distance, il you use an intensity sensor at infinite you won't see the spot and you will have the mix color.
In near field you will see the mix at the center and colored spot at the exterior.
For intensity sensor far field (infinite) is the default setup.
Thanks
