Ansys Learning Forum Forums Discuss Simulation Optics Mix color with Integrating sphere or sensor in LED RGB sourse Reply To: Mix color with Integrating sphere or sensor in LED RGB sourse
irocha
Hello Thomas,
I understand what you are saying, only that when I have the result of the luminous flux emitted by each color, we will obtain red, green and blue spots on the sensor, correct?
What I am looking for is to know how the fluxes, that I put for each color on the set up, would be mixed, that is why I exemplified the equipment of an integrating sphere since it gives you the mixture of the 3 colors.
An extra question, has the capabilities to made Far field sensor in Speos?
Thanks
