Ansys Learning Forum Forums Discuss Simulation Optics Mix color with Integrating sphere or sensor in LED RGB sourse Reply To: Mix color with Integrating sphere or sensor in LED RGB sourse
Thomas Martineau
In Speos, you need to set the sensor to colorimetric or spectral. You can use irradiance (lux at a given distance) or radiance sensor looking to the LED or intensity snesor (by default at the infinite, but you can also set to near field to check closer to the LED).
After the simulation you cna check the color on the result nad if you have set layer to source in the sensor, you cna change the flux of R,G and B independantly and verify the resulting color without relaunching the simulation.
Thanks
Thomas
