Ansys Learning Forum Forums Discuss Simulation Fluids Partial slip for rarefied flow regime Reply To: Partial slip for rarefied flow regime
S.Shrestha-4
This is my setup. I reaaly could not find out what problem there is, but maybe you can see it?
Fluent
Version: 3d, dp, dbns imp, lam (3d, double precision, density-based implicit, laminar)
Release: 24.1.0
Title:
Models
   Model                        Settings
   Space                        3D
   Time                         Steady
   Viscous                      Laminar
   Heat Transfer                Enabled
   Solidification and Melting   Disabled
   Radiation                    None
   Species                      Disabled
   Coupled Dispersed Phase      Disabled
   NOx Pollutants               Disabled
   SOx Pollutants               Disabled
   Soot                         Disabled
   Mercury Pollutants           Disabled
   Structure                    Disabled
   Acoustics                    Disabled
   Eulerian Wall Film           Disabled
   Potential/Electrochemistry   Disabled
   Multiphase                   Disabled
Material Properties
   Material: air (fluid)
      Property               Units      Method     Value(s)
      Density                kg/m^3     constant   1.225
      Cp (Specific Heat)     J/(kg K)   constant   1006.43
      Thermal Conductivity   W/(m K)    constant   0.0242
      Viscosity              kg/(m s)   constant   1.7894e-05
      Molecular Weight       kg/kmol    constant   28.966
   Material: aluminum (solid)
      Density                kg/m^3     constant   2719
      Cp (Specific Heat)     J/(kg K)   constant   871
      Thermal Conductivity   W/(m K)    constant   202.4
Cell Zone Conditions
   Zones
      name    id   type
      fluid   11   fluid
   Setup Conditions
      fluid
         Condition       Value
         Frame Motion?   no
         Mesh Motion?    no
Boundary Conditions
   Zones
      name                  id   type
      bottom_plane          14   symmetry
      nozzle_side_wall      15   wall
      nozzle_profile_wall   16   wall
      plume_midplane        19   symmetry
      nozzle_midplane       17   symmetry
      inlet                 13   pressure-inlet
      outlet                18   pressure-outlet
   Setup Conditions
      bottom_plane
         Condition   Value
      nozzle_side_wall
         Condition                            Value
         Thermal BC Type                      Temperature
         Temperature [K]                      453.15
         Wall Motion                          Stationary Wall
         Shear Boundary Condition             Partial Slip For Rarefied Gases
         Momentum Accommodation Coefficient   0.8
         Thermal Accommodation Coefficient    0.85
      nozzle_profile_wall
         Condition                            Value
      plume_midplane
         Condition   Value
      nozzle_midplane
         Condition   Value
      inlet
         Condition                   Value
         Gauge Total Pressure [Pa]   200
         Total Temperature [K]       453.15
      outlet
         Condition             Value
         Gauge Pressure [Pa]   20
Solver Settings
   Equations
      Equation   Solved
      Flow       yes
   Numerics
      Numeric                         Enabled
      Absolute Velocity Formulation   yes
   Under-Relaxation Factors
      Variable   Relaxation Factor
      Solid      1
   Linear Solver
      Variable   Solver Type   Termination Criterion   Residual Reduction Tolerance
      Flow       F-Cycle       0.1
   Discretization Scheme
      Variable   Scheme
      Flow       Second Order Upwind
   Time Marching
      Parameter        Value
      Solver           Implicit
      Courant Number   5
   Solution Limits
      Quantity                         Limit
      Minimum Absolute Pressure [Pa]   1
      Maximum Absolute Pressure [Pa]   5e+10
      Minimum Static Temperature [K]   1
      Maximum Static Temperature [K]   5000
