Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Partial slip for rarefied flow regime › Reply To: Partial slip for rarefied flow regime
August 13, 2024 at 2:23 pm
Moving won't alter the set up issue - it's just an example model I had loaded.
That is a Scheme error so you may find it won't run, and as I have no idea why it triggers in this case I don't know what the result would be if it did.
