Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Laser Melting heat source UDF issue [FLUENT Crashing] › Reply To: Laser Melting heat source UDF issue [FLUENT Crashing]
August 13, 2024 at 1:32 pm
You may have created a register, unless you've set refinement/coarsening you've not adapted the model so you should be OK.Â
