Ansys Learning Forum Forums Discuss Simulation Fluids Laser Melting heat source UDF issue [FLUENT Crashing] Reply To: Laser Melting heat source UDF issue [FLUENT Crashing]
Kanak BUET19
In my code, I am taking value of  C_VOF_G . Apparently it seems in order for this to work , I need to set : solve/set/expert/Keep temporary solver memory from being feed? to YES
but, upon doing this I found this message :
Info: Expert option for not freeing temporary solver memory is incompatible with adaption in parallel.
(Also I have used mesh adaption to patch solid domain )
Since, fluent doesnt work in serial in recent days, I need your guidance for storing the VOF Gradient value somehow. Any suggestions?Â
