Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Meshing heat exchanger initial simulation no baffles › Reply To: Meshing heat exchanger initial simulation no baffles
August 13, 2024 at 10:40 am
Are you using size functions or edge sizing? If the latter are you using hard or soft settings? From there, you're stretching the cells so any cross flow is going to encounter very high aspect ratio cells which isn't good.Â
