Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Combining Results from 2 Different Models › Reply To: Combining Results from 2 Different Models
August 13, 2024 at 9:16 am
Aurojyoti Prusty
Hi Fu Hsien,
I suppose you want to see the effect of the two loading on your model (combining all bodies) at the same time ?. If that is true, you can apply the two load in two different steps which can be achieved in the analysis settings of the static structural tree. That would be more realistic than combining two different bodies and applying different loadings. Please let us know if that is what want to do or you have specific requirements of applying the two load in a sequential manner.
Thanks,
AurojyotiÂ
