Ansys Learning Forum Forums Discuss Simulation Electronics How to “connect” 2 different ground planes? Reply To: How to “connect” 2 different ground planes?
Stefano R
Charlotte,
Thank you for the response. I think your solution works if the ground planes share an edge. What if I wish to connect them internally in the model? Would a lumped port work? For example, attached is a picture of an internal plane in red touching the top ground and bottom ground.
Thanks.
