Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Inverse Design Freezing Issue › Reply To: Inverse Design Freezing Issue
Guilin Sun
Somehow my reply was not successful so I duplicate it again:
since we are not allowed to check files on the forum, please contact your account manager for the files.
Did you check the "task manager" during the simulation and see if the memory is the bottleneck? Even though one simulation does not need a lot of memory iteration may need.
 without error message it is hard for us to find a solution.
You may first try 2D simulation, or if you have VarFDTD try it first.
