Ansys Learning Forum › Forums › Discuss Simulation › Photonics › scattering calculation with gaussian beam in FDTD › Reply To: scattering calculation with gaussian beam in FDTD
August 12, 2024 at 5:30 pm
Guilin Sun
NA beam is diffraction-limited vectorial fields. High NA beam profile will have obvious diffraction pattern, which is correct: https://optics.ansys.com/hc/en-us/articles/360034382854-Plane-wave-and-beam-source-Simulation-object
For low NA, the bem size is large, and al may need better PML performance. Please use larger simulation spans and more PML layers and make sure source is wide enough not cliping the field. You can use log scale to check the intensity at the edge.
