Ansys Learning Forum Forums Discuss Simulation Fluids Volume Fraction too Low. How to Improve? Reply To: Volume Fraction too Low. How to Improve?
abdullahhassan
Yes, I tried to export the data previously using two methods
1- Making report defination for temperature etc and later exporting that data in excel. (the issue is, the data only comes with reference to timestep, flowtime or iterations.
2- Exporting the date using File > export > solution data > ACSII and exporting into excel. (The data comes with reference to Node Number).
What is the best possible way to export the data out of ansys + if I choose method 2 then should i first find out node numbers of Interface where i want to calculate heat flux etc and then average out heat flux on all the nodes of interface?
