Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Hoop Tensile stress on a pipe until failure › Reply To: Hoop Tensile stress on a pipe until failure
August 12, 2024 at 2:53 pm
Note the error message about an internal solution magnitude being exceeded for Node 122158, Body SolidModel.1,DOF UX. You may try plotting the damage variable on that body. If it has reached its maximum value then it may indicate that the body is no longer being adequately constrained, hence the convergence issue.
