Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Ring Resonator: Transmission in the Ring is greater than 1 › Reply To: Ring Resonator: Transmission in the Ring is greater than 1
August 12, 2024 at 11:29 am
thank you for the answer.
The port in the ring itself is positioned at the bottom and the port on the waveguide is placed at its end (see the picture).
I found that increasing the simulation time further to 200000 fs and using 64 PML layers got rid of the issue. However, I would think there could be still an issue, as the simulation time seems unnecessary high.
