Ansys Learning Forum Forums Discuss Simulation Photonics CHARGE: Simulation Halting at 8.5 V During Voltage Sweep from 0 V to 12 V Reply To: CHARGE: Simulation Halting at 8.5 V During Voltage Sweep from 0 V to 12 V
Niki Papachristou
Hi Bharathy,
Thank you for reaching out to us. For you case may I ask you whether you have checket your CHARGE simulation using the Partitioned volumes in finite element solvers - Simulation object?
After partitioning the sumulation if you have a none in one of your domains means that you dont have a material there and the simulation might be stoping for that.
Let me know if that's the case.
Kind Regards,
Niki
