Ansys Learning Forum › Forums › Discuss Simulation › Fluids › fluent relaxation factor › Reply To: fluent relaxation factor
SRP
Under-Relaxation Factors contains the under-relaxation factors for all equations that are being solved with the pressure-based solver
High order relaxation enables the relaxation of high order terms to aid in the solution behavior of flow simulations when higher order spatial discretization is used.
