Ansys Learning Forum Forums Discuss Simulation General Mechanical Thermal element with higher order in only one direction Reply To: Thermal element with higher order in only one direction
Leon15
Hello, thanks for the quick answer. I tried deleting all the mid nodes on elements (solid279) as a test using the following command:
MODMSH,DETACH
EMID,REMOVE,ALL
However, it is not doing anything. Am I missing something? Also, not sure to see how EMOD (EMODIF?) can be helpful in this case.
