Ansys Learning Forum Forums Discuss Simulation Fluids Volume Fraction too Low. How to Improve? Reply To: Volume Fraction too Low. How to Improve?
Use the Fluxes option in the Results panel. The surface integrals are using some averaging schemes so you need to understand the underlying maths.
The HTC is defined in the User's Guide, and is a function of reference temperature. Hence HTC can be pretty much any value you want based on the reference.Â
