Ansys Learning Forum Forums Discuss Simulation LS Dyna DMP not working Reply To: DMP not working
Reno Genest
Hello Javat,
SMP does not scale well beyond about 8 cores. So, you should not see a speedup beyond 8 cores and you may actually see speed degradation with more cores.
When you activate DMP, the MPP version of LS-DYNA is used (as opposed to SMP). MPP will scale well beyond 8 cores and it is the solver to use to utilize all your cores.
With MPP LS-DYNA you get mesXXXX files. For example, if you run on 24 cores, you will get mes0000 - mes0023 files in the working directory and the error message can be found in one or many mesXXXX files. So, you have to look at all the mesXXXX to find a meaningful error message. You can also use the following webapp to save time and extract error messages from mesXXXX automatically:
https://nagasairam112-check-dyna-errors-error-dyna-check-rq20je.streamlit.app/
Hopefully, you will extract a proper error message that will help you troubleshoot the problem.
You will find more information on SMP and MPP LS-DYNA here:
Microsoft PowerPoint - mpp_201305 (lstc.com)
Let me know how it goes.
Reno.
