Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Volume Fraction too Low. How to Improve? › Reply To: Volume Fraction too Low. How to Improve?
abdullahhassan
Thankyou so much Sir. I learned alot while communicating with you in this thread.
I have a last question.
As you know, I have defined Heat flux (-5858W/m2) value at tubewall:1 (heat flux tube fluid should absorb). And by changing temperature at reference values tab, I am also able to achieve heat transfer coefficient(+ve) and heat flux (-ve) at boundaries in vapor domain.
but when I checked volume integrals, the heat flux at the tube wall is +ve and heat transfer coefficient due to heat flux becomes negative
1- why tubewall:1 & tube wall in both surface & volume integrals have opposite signs.
2- why -5858W/m2 is not reflecting at volume integral > tube wall ?
Is there anyway, I can calculate or understand heat flux calculations or what properties are really effecting it like for heat transfer coefficinet it is heff = q/Twall - Tref.
