Ansys Learning Forum Forums Discuss Simulation Fluids Ansys Fluent UDF: DEFINE_DPM_BC Reply To: Ansys Fluent UDF: DEFINE_DPM_BC
kiran.purushothamakeshavan
Thanks for your reply.
The issue was that I did not build the udf from x86_x64 VS prompt. After opening fluent from Visual Studio prompt UDF seems to be loading without issues.
However, I have an issue where the particles in my model seem to not stick to the boundary. below I’ve copied the UDF for your reference.
I expected to see certain particles bounce while the rest of them to stick to the surface, here I do not see the particles bounce or stick.
#include “udf.h”
#include “dpm.h”
#include “math.h”
#define Rho_air 1.225  /* Air density in kg/m^3 */
#define Cd 0.47        /* Drag coefficient for a sphere */
#define mu 0.5         /* Coefficient of friction */
/* Define your boundary condition function */
DEFINE_DPM_BC(particle_bc, p, t, f, normal, dim)
    real V = sqrt(P_VEL(p)[0] * P_VEL(p)[0] + P_VEL(p)[1] * P_VEL(p)[1] + P_VEL(p)[2] * P_VEL(p)[2]);  /* Velocity magnitude in m/s */
    real radius = P_DIAM(p) / 2.0;
    real A = M_PI * radius * radius;  /* M_PI is a constant for π */
    /* Get the thread and cell pointers */
    Thread *t0 = P_CELL_THREAD(p);
    cell_t c0 = P_CELL(p);
    /* Get local pressure at the particle’s location */
    real P_local = C_P(c0, t0);
    /* Calculate aerodynamic force Fa */
    real Fa = 0.5 * Rho_air * A * Cd * V * V;
    /* Calculate normal force Fn */
    real Fn = P_local * A;
    /* Calculate frictional force Ff */
    real Ff = mu * Fn;
    /* Coefficient of restitution */
    real e;
    if (Fa > Ff)
        /* Particle needs to bounce with a coefficient of restitution of 1 */
        e = 1.0;
        /* Update the particle velocity to simulate the bounce */
        for (int i = 0; i < dim; i++)
            P_VEL(p)[i] = -e * P_VEL(p)[i];
        return PATH_ACTIVE; /* No adhesion */
    else
        /* Particle sticks to the boundary with a coefficient of restitution of 0 */
        // e = 0.0;
        /* Update the particle velocity to simulate sticking */
            P_VEL(p)[i] = 0;
        P_USER_REAL(p, 0) = 1.;
        return PATH_ACTIVE; /* Adhesion */
Can you please comment on the code?
