Ansys Learning Forum › Forums › Discuss Simulation › Fluids › solution not converged (two-way FSI) › Reply To: solution not converged (two-way FSI)
August 8, 2024 at 12:27 pm
Hello Farah,
Please check which participant failed. You can inspect the log files of each participant for this and adjust the settings accordingly to get the converged solution.
From error, it appears that the MAPDL Solution fails to converge.Â
You can find some best practices to improve the accuracy:Â Improving the Accuracy of Transient Analyses (ansys.com)
Hope this helps.
