Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › How to use ESCHECK command in Ansys Mechanical ? › Reply To: How to use ESCHECK command in Ansys Mechanical ?
Asitang Lahurikar
Hi Leo,
Requesting and checking for Newton-Raphson Residual plots could be the best way to know and locate the regions in your model that led to convergence difficulties. It might be a good idea to request for about 5 Newton-Raphson residuals to begin with. If you haven’t already, I would suggest you to give this a try. Additionally, you may use "Identify Element Violations" option that is available under "Solution Information" to find the problematic elements. To know more about it, please refer to the help document here - 25.2.19. Element n Located in Body (and maybe other elements) Has Become Highly Distorted (ansys.com)
Asitang
