Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Simulation error while doing the LPBF process using the wizard. › Reply To: Simulation error while doing the LPBF process using the wizard.
Akshay Maniyar
Do you have any user-defined results under output? Is the model running completely if you suppress all the output quantities?
Thanks,
Akshay Maniyar
