Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Volume Fraction too Low. How to Improve? › Reply To: Volume Fraction too Low. How to Improve?
August 7, 2024 at 10:07 am
The flux over the wall & shadow pair should be zero unless you altered anything: ie heat goes in one side and out the other. So, the sum of inlet, outlet and tubewall:1 should be near enough zero; if it's 3W then review the convergence guidelines in the training materials in Learning.Â
