Ansys Learning Forum Forums Discuss Simulation Fluids Single floating structure Ansys AQWA Reply To: Single floating structure Ansys AQWA
S.S.S.ShankaVasuki
thank you for response.
Yes the reference results are divided by the incident wave amplitude. I also found that the reference article's time domain RAO is lower than what they get using the diffraction analysis. So, do you suggest that there might be an error in the reference article with respect to these plots?
